[postgis-devel] ERROR: operator class "brin_geography_inclusion_ops" does not exist for access method "brin"
Justin Pryzby
pryzby at telsasoft.com
Tue Nov 2 12:10:43 PDT 2021
On Tue, Nov 02, 2021 at 03:00:36PM -0400, Regina Obe wrote:
> DO NOT RUN uninstall_postgis.sql -- it will destroy your data.
Yea - if I had to do this, I would have to dump the two GIS columns on affected
servers and recreate them later. Which I've done before.
> If you are up for it, I can let you know when I think I have something and
> you can test it out.
Yes, can do.
> It will be hard I think to be sure if we got it working right without having
> an install already suffering the issue.
I have 4 affected databases (and about 30 upgraded without hitting this issue).
This isn't causing any problem for me, so I can wait for your fix.
However, I also mentioned the need to "DROP CASTS" in order to upgrade to the
latest postgis, and in that case I already dropped them as a quick fix to allow
the upgrade to proceed, and cannot help test that part.
Thanks,
Justin
