[postgis-devel] [postgis-users] PSC Vote: Keep or drop Flatgeobuf in PostGIS 3.2.0
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Nov 25 09:07:55 PST 2021
As an aside, I appreciate this explanation on speed and benefits, Björn,
of FlatGeobuf.  Thanks,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-11-25 7:32 a.m., Björn Harrtell wrote:
> Just a FWIW,
> FlatGeobuf is actually not prioritizing space optimization, instead
> designed for simplicity and speed. Even so, it can be smaller than both
> shapefile and geojson but it depends on data. But so, it can make sense
> to compress if space optimization is required.
> The primary reason for why FlatGeobuf is fast is the use of Flatbuffers
> which is not far from C structs (i.e direct access, no decode, no extra
> allocations needed) but has a stable platform independent wire
> format. If created without index FlatGeobuf can be both written and read
> as stream, which makes it very fast as a system to system transfer
> format. If written with an index a FlatGeobuf can be accessed with a
> bbox filter very efficiently because it has a guaranteed balanced
> Hilbert R-tree, so can be traversed with forward seek and found data
> locality is good because data is ordered by the spatial index.
> Unfortunately bytea input/output does not allow full advantage of these
> properties - something like COPY would be better (since it can be streamed).
> /Björn
> Den tors 25 nov. 2021 kl 00:10 skrev Regina Obe <lr at pcorp.us
> <mailto:lr at pcorp.us>>:
>     As mentioned on IRC just reiterated here. ____
>     __ __
>     I would like to see ST_AsFlatGeoBuf in there. Here are my reasons.____
>     __ __
>     1) To Bruce’s point that sure ogr_fdw can read it, I’m more
>     interested in the writing of it (which at least I can’t do from
>     scratch with ogr_fdw) and getting out of the database onto the
>     command line is not one of my great ambitions in life.____
>     __ __
>     2) The fact it is a lighter weight format than ST_AsGeoJSON which
>     has the same 1GB limitation.____
>     Or as mentioned https://flatgeobuf.org/ <https://flatgeobuf.org/> a
>     better shapefile format (for < 1GB)____
>     And the fact that FlatGeobuf is about 50% lighter than GeoJSON ____
>      From site:____
>        (shapefile 1, FlatGeoBuf 0.77,  GeoJSON  1.2)____
>     __ __
>     Means I can stuff much more data in the 1GB limit than I can in
>     GeoJSON.____
>     Though not sure about how that places with the other attribute data
>     if they are compacted as efficiently.____
>     __ __
>     3) Given it is  demonstrated it can work fine with leaflet and
>     openlayers means it is possible to hook it into something like ____
>     https://github.com/CrunchyData/pg_featureserv
>     <https://github.com/CrunchyData/pg_featureserv> ____
>     __ __
>     as an alternative format to geojson (not saying you should Martin
>     Davis – just throwing it out there J)____
>     __ __
>     4) One more reason to fight that 1GB limit – as postgis raster is
>     impacted by that too.____
>     __ __
>     __ __
>     Thanks,____
>     Regina____
>     __ __
>     *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org
>     <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Björn
>     Harrtell
>     *Sent:* Wednesday, November 24, 2021 5:26 PM
>     *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org
>     <mailto:postgis-devel at lists.osgeo.org>>
>     *Cc:* PostGIS Users Discussion <postgis-users at lists.osgeo.org
>     <mailto:postgis-users at lists.osgeo.org>>
>     *Subject:* Re: [postgis-users] [postgis-devel] PSC Vote: Keep or
>     drop Flatgeobuf in PostGIS 3.2.0____
>     __ __
>     Even though I spent quite a bit of effort on implementing this stuff
>     and I'm sure I can fix the crashers I agree with the arguments to
>     remove it. That is, 1GB limit is really bad and better to use GDAL
>     which has a well maintained impl of it.____
>     __ __
>     If there was a way to stream in and out binary with custom encoding
>     and no size limit (i.e COPY with custom/ext binary format) it could
>     make sense but I don't think that is going to happen any time soon.____
>     __ __
>     Oh well, it was fun. Some of it. 😂____
>     __ __
>     PS. ST_AsGeobuf should be deprecated/removed too - it's even less
>     useful IMHO.____
>     __ __
>     PS2. I do still believe in FlatGeobuf and it is used in production.
>     ;)____
>     __ __
>     /Björn____
>     Den ons 24 nov. 2021 22:26Bruce Rindahl <bruce.rindahl at gmail.com
>     <mailto:bruce.rindahl at gmail.com>> skrev:____
>         FWIW I say remove it and seriously think about not including it
>         at all.  Looks like you can use the format right now via ogr_fdw
>         using GDAL. ____
>         __ __
>         On Wed, Nov 24, 2021 at 12:51 PM Regina Obe <lr at pcorp.us
>         <mailto:lr at pcorp.us>> wrote:____
>             FWIW it’s already in GDAL since 3.1 and yah GDAL is a better
>             home since it doesn’t have the  1GB PostgreSQL limitation____
>             ____
>             https://gdal.org/drivers/vector/flatgeobuf.html
>             <https://gdal.org/drivers/vector/flatgeobuf.html>____
>             ____
>             Also here are OpenLayers and Leaflet examples for those not
>             familiar with the format____
>             ____
>             OpenLayers: https://flatgeobuf.org/examples/openlayers/
>             <https://flatgeobuf.org/examples/openlayers/>____
>             ____
>             ____
>             Leaflet: https://flatgeobuf.org/examples/leaflet/
>             <https://flatgeobuf.org/examples/leaflet/>____
>             ____
>             Thanks,____
>             Regina____
>             ____
>             Of *Darafei "Kom?pa" Praliaskouski
>             *Sent:* Wednesday, November 24, 2021 3:27 PM
>             Keep or drop Flatgeobuf in PostGIS 3.2.0____
>             ____
>             Hi,
>             I have not seen flatgeobuf in the wild, and I believe it can
>             be safely removed. ____
>             ____
>             The current implementation is impaired by Postgres' life
>             choices of 1GB limit and thus not usable for any data, just
>             size-limited subset. ogr2ogr seems like a better suited
>             place for it to reside.____
>             ____
>             I'm -0 on adding flatgeobuf to core, and -1 on releasing
>             with known crashers. This would converge to "remove if
>             nobody can fix crashers".____
>             ____
>             ____
>             On Wed, Nov 24, 2021 at 11:10 PM Regina Obe <lr at pcorp.us
>                 This is a PSC vote, but we would like some feedback on
>                 this from packagers
>                 and users as such comments will sway our vote.
>                 We have two blockers that center around the new
>                 FlatGeoBuf format.
>                 https://trac.osgeo.org/postgis/ticket/5005
>                 <https://trac.osgeo.org/postgis/ticket/5005>  (this one
>                 is easily
>                 replicatable)
>                 https://trac.osgeo.org/postgis/ticket/5014
>                 <https://trac.osgeo.org/postgis/ticket/5014> (this one I
>                 can only replicate
>                 with the cowbuilder setup Bas Cowenberg provided)
>                 both I think are manifestations of the same problem how
>                 the header is
>                 derived and what it's doing with numeric and geometry
>                 fields.
>                 I've taken a stab at troubleshooting and fixing, but did
>                 not have much luck.
>                 That said, if anyone is willing to help fix that would
>                 be great and fix
>                 within a 1 to 2 week time period.
>                 If not I feel that we really need to take it out of our
>                 PostGIS 3.2.0
>                 release (which will be going on to 3.2.0beta2).
>                 I'd like to release PostGIS 3.2.0beta2 in about a week
>                 or so with flatgeobuf
>                 fixed or removed.  If removed, we'll  push flatgeobuf to
>                 PostGIS 3.3.0
>                 cycle.
>                 Thanks,
>                 Regina
>                 _______________________________________________
>                 postgis-devel mailing list
>                 https://lists.osgeo.org/mailman/listinfo/postgis-devel
>                 <https://lists.osgeo.org/mailman/listinfo/postgis-devel>____
>         postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
