[postgis-devel] ERROR: operator class "brin_geography_inclusion_ops" does not exist for access method "brin"
Justin Pryzby
pryzby at telsasoft.com
Sun Oct 10 12:47:43 PDT 2021
I pg_upgraded another instance and hit this error again.
ts=# SELECT postgis_full_version();
postgis_full_version | POSTGIS="3.1.4 ded6c34" PGSQL="130" (procs need upgrade for use with PostgreSQL "140") GEOS="3.9.1-CAPI-1.14.2" PROJ="7.2.1" LIBXML="2.9.1" LIBJSON="0.11"
ts=# SELECT postgis_extensions_upgrade();
NOTICE: Packaging extension postgis
CONTEXT: SQL statement "ALTER EXTENSION postgis ADD OPERATOR CLASS brin_geography_inclusion_ops USING brin"
PL/pgSQL function inline_code_block line 3 at SQL statement
SQL statement "CREATE EXTENSION postgis SCHEMA public VERSION unpackaged;ALTER EXTENSION postgis UPDATE TO "3.1.4""
PL/pgSQL function postgis_extensions_upgrade() line 68 at EXECUTE
The "procs need upgrade" warning was not present in v13 before the upgrade.
[pryzbyj at database ~]$ sudo grep gis /var/log/yum.log
Apr 09 16:51:44 Updated: postgis31_13-3.1.1-3.rhel7.x86_64
Apr 09 16:51:44 Updated: postgis31_13-client-3.1.1-3.rhel7.x86_64
Oct 10 14:57:59 Updated: postgis31_13-3.1.4-1.rhel7.x86_64
Oct 10 14:57:59 Updated: postgis31_13-client-3.1.4-1.rhel7.x86_64
Oct 10 14:58:38 Installed: postgis31_14-3.1.4-1.rhel7.x86_64
Oct 10 14:58:38 Installed: postgis31_14-client-3.1.4-1.rhel7.x86_64
Am I supposed to have run postgis_extensions_upgrade() after installing a
patchlevel update to postgis, and before running pg_upgrade ?
Since there's nothing to enforce that, what am I supposed to do now ?
If I comment enough parts out, this works:
ts=# begin; CREATE OPERATOR CLASS brin_geography_inclusion_ops
DEFAULT FOR TYPE geography
USING brin AS
FUNCTION 1 brin_inclusion_opcinfo(internal),
FUNCTION 2 geog_brin_inclusion_add_value(internal, internal, internal, internal),
FUNCTION 3 brin_inclusion_consistent(internal, internal, internal),
FUNCTION 4 brin_inclusion_union(internal, internal, internal),
OPERATOR 3 &&(geography, geography),
-- OPERATOR 3 &&(geography, gidx),
-- OPERATOR 3 &&(gidx, geography),
-- OPERATOR 3 &&(gidx, gidx),
STORAGE gidx;
BEGIN
Justin
