[postgis-devel] ERROR: operator class "brin_geography_inclusion_ops" does not exist for access method "brin"
Justin Pryzby
pryzby at telsasoft.com
Mon Oct 25 05:33:26 PDT 2021
On Mon, Oct 25, 2021 at 02:50:15AM -0400, Regina Obe wrote:
> > The server which has this error has:
> > brin | brin_geography_inclusion_ops | &&(gidx,gidx) | 3 | search
> > brin | brin_geography_inclusion_ops | &&(geography,gidx) | 3 | search
> > brin | brin_geography_inclusion_ops | &&(gidx,geography) | 3 | search
> Okay I found the ticket where I ran into the same issue.
> Looks like it was closed cause it was deemed only an issue for 9.3
> https://trac.osgeo.org/postgis/ticket/3633
> Although from your above, it looks like you already have this operator
> class, but I'm not sure what command you used to generate that search
> result.
It's \dAo
> What happens if you try to do this in that database:
> ALTER EXTENSION postgis ADD OPERATOR CLASS brin_geography_inclusion_ops USING brin;
ts=# ALTER EXTENSION postgis ADD OPERATOR CLASS brin_geography_inclusion_ops USING brin;
ERROR: extension "postgis" does not exist
Thanks for looking at this.
Justin
