[postgis-devel] ERROR: operator class "brin_geography_inclusion_ops" does not exist for access method "brin"
Justin Pryzby
pryzby at telsasoft.com
Sun Oct 31 18:38:22 PDT 2021
On Sun, Oct 31, 2021 at 09:26:45PM -0400, Regina Obe wrote:
> > ts=# ALTER EXTENSION postgis ADD OPERATOR CLASS
> > brin_geography_inclusion_ops USING brin;
> > ERROR: extension "postgis" does not exist
> > Thanks for looking at this.
> [Regina Obe]
> Okay that's puzzling. Did you not change this one to be an extension based one?
Yea, it's what I said:
On Sat, Oct 09, 2021 at 12:11:22PM -0500, Justin Pryzby wrote:
> On Sat, Oct 09, 2021 at 01:02:40PM -0400, Regina Obe wrote:
> > When did you switch from non-extension to extension version?
> Do you mean CREATE EXTENSION rather than \i postgis.sql ? I suppose the answer
> is that I haven't yet switched, or finished switching.
> I'd prefer to use "CREATE EXTENSION", but it looks like on many of our
> instances, postgis is not listed in psql \dx, and it was never clear to me how
> to fix it. We only have postgis for 2 columns used by mapscript, so if that
> works, it's good enough for us.
I found this old ticket/thread where I reported a previous upgrade issue, and
gave some more context.
https://trac.osgeo.org/postgis/ticket/4516
If the response ends up being that "you needed to switch from scripts to
extensions, and you didn't do that, and it's not supported", that's okay.
Essentially my problem report is to point out that that that upgrade was never
enforced, and so you're not guaranteed that anybody actually did it. And
postgis_extensions_upgrade() is sometimes failing to handle that case. If
that's not expected to work for unpackaged postgis, it should probably detect
that case and throw an error, to force users like me to run
uninstall_postgis.sql and then recreate it as an extension. Or maybe it's
intended to work..
Justin
