[postgis-devel] getPoint aligned/unaligned reads
Paul Ramsey pramsey at cleverelephant.ca
Sun Sep 26 13:01:56 PDT 2021
> On Sep 26, 2021, at 11:32 AM, Sandro Santilli <strk at kbt.io> wrote:
> I must have lost track but.. is POINTARRAY nowadays ensured to always
> be double-aligned or not ? I'm asking because of issue #4990 which
> reveals some problem on 32bit and I suspect (but didn't confirm yet)
> that it may be due to using the getPoint_cp function, which does
> the cast from char* to double*...
Since 2.0 the underlying double array in a POINTARRAY is double aligned, which is the reason getPoint2d_cp() works at all on platforms that disallow unaligned access (hard to find those nowadays though).
> Paul: as the last one who touched the serialization format, is it
> always safe to use getPoint_cp or not, to your knowledge ?
It is always safe, the serialization is carefully set up to retain double alignment of the double arrays.
P
> --strk;
>  Libre GIS consultant/developer
>  https://strk.kbt.io/services.html
