[postgis-devel] closest_segment_2d corner case (32bit failure)
Sandro Santilli
strk at kbt.io
Wed Sep 29 14:03:25 PDT 2021
On Wed, Sep 29, 2021 at 08:36:05PM +0200, Raúl Marín wrote:
> Hi,
> Regarding the tests: distance2d_sqr_pt_seg used to be "tested" by all the
> users of ptarray_dp_findsplit_in_place (like simplify) but that was removed
> as part of the same patch (with included many other commits).
Do you have a reference to that patch ? I didn't quite understood what
you mean by "that was removed".
--strk;
