[postgis-devel] PostGIS upgrade error
Regina Obe
lr at pcorp.us
Thu Aug 18 13:21:07 PDT 2022
It looks like you are running a 2.4 before the view upgrade fix was applied. If you can’t upgrade your old cluster to the latest 2.4 micro, you can apply the attached create view definitions and that should fix your issue.
The issue is that I think in PG 12, pg_constraint.consrc was taken out so we had to rework the views to use pg_get_constraintdef function instead.
Since pg_upgrade tries to run the old view definition, it fails.
Hope that helps,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nikhil Shetty
Sent: Thursday, August 18, 2022 11:50 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: [postgis-devel] PostGIS upgrade error
Hi Team,
We are upgrading PostgreSQL (11.7 to 13.6) and PostGIS (2.4.4 to 3.2.1) but we are getting below error during pg_upgrade.
pg_restore: while PROCESSING TOC:
pg_restore: from TOC entry 309; 1259 17730 VIEW geometry_columns postgres
pg_restore: error: could not execute query: ERROR: column s.consrc does not exist
LINE 28: "replace"("split_part"("s"."consrc", ''''::"text...
HINT: Perhaps you meant to reference the column "s.conkey" or the column "s.conbin".
Command was:
-- For binary upgrade, must preserve pg_type oid
SELECT pg_catalog.binary_upgrade_set_next_pg_type_oid('17732'::pg_catalog.oid);
-- For binary upgrade, must preserve pg_type array oid
SELECT pg_catalog.binary_upgrade_set_next_array_pg_type_oid('17731'::pg_catalog.oid);
-- For binary upgrade, must preserve pg_class oids
SELECT pg_catalog.binary_upgrade_set_next_heap_pg_class_oid('17730'::pg_catalog.oid);
CREATE VIEW "public"."geometry_columns" AS
SELECT ("current_database"())::character varying(256) AS "f_table_catalog",
"n"."nspname" AS "f_table_schema",
"c"."relname" AS "f_table_name",
"a"."attname" AS "f_geometry_column",
COALESCE("public"."postgis_typmod_dims"("a"."atttypmod"), "sn"."ndims", 2) AS "coord_dimension",
COALESCE(NULLIF("public"."postgis_typmod_srid"("a"."atttypmod"), 0), "sr"."srid", 0) AS "srid",
("replace"("replace"(COALESCE(NULLIF("upper"("public"."postgis_typmod_type"("a"."atttypmod")), 'GEOMETRY'::"text"), "st"."type", 'GEOMETRY'::"text"), 'ZM'::"text", ''::"text"), 'Z'::"text", ''::"text"))::character varying(30) AS "type"
FROM (((((("pg_class" "c"
JOIN "pg_attribute" "a" ON ((("a"."attrelid" = "c"."oid") AND (NOT "a"."attisdropped"))))
JOIN "pg_namespace" "n" ON (("c"."relnamespace" = "n"."oid")))
JOIN "pg_type" "t" ON (("a"."atttypid" = "t"."oid")))
LEFT JOIN ( SELECT "s"."connamespace",
"s"."conrelid",
"s"."conkey",
"replace"("split_part"("s"."consrc", ''''::"text", 2), ')'::"text", ''::"text") AS "type"
FROM "pg_constraint" "s"
WHERE ("s"."consrc" ~~* '%geometrytype(% = %'::"text")) "st" ON ((("st"."connamespace" = "n"."oid") AND ("st"."conrelid" = "c"."oid") AND ("a"."attnum" = ANY ("st"."conkey")))))
"s"."conrelid",
"s"."conkey",
("replace"("split_part"("s"."consrc", ' = '::"text", 2), ')'::"text", ''::"text"))::integer AS "ndims"
WHERE ("s"."consrc" ~~* '%ndims(% = %'::"text")) "sn" ON ((("sn"."connamespace" = "n"."oid") AND ("sn"."conrelid" = "c"."oid") AND ("a"."attnum" = ANY ("sn"."conkey")))))
"s"."conrelid",
"s"."conkey",
("replace"("replace"("split_part"("s"."consrc", ' = '::"text", 2), ')'::"text", ''::"text"), '('::"text", ''::"text"))::integer AS "srid"
WHERE ("s"."consrc" ~~* '%srid(% = %'::"text")) "sr" ON ((("sr"."connamespace" = "n"."oid") AND ("sr"."conrelid" = "c"."oid") AND ("a"."attnum" = ANY ("sr"."conkey")))))
WHERE (("c"."relkind" = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"])) AND (NOT ("c"."relname" = 'raster_columns'::"name")) AND ("t"."typname" = 'geometry'::"name") AND (NOT "pg_is_other_temp_schema"("c"."relnamespace")) AND "has_table_privilege"("c"."oid", 'SELECT'::"text"));
-- For binary upgrade, handle extension membership the hard way
ALTER EXTENSION "postgis" ADD VIEW "public"."geometry_columns";
We are creating below links before the upgrade
>>>>>>>:/usr/pgsql-13/lib $ ls -l | grep postgis
lrwxrwxrwx 1 root root 30 Aug 18 02:35 postgis-2.4.so <http://2.4.so> -> /usr/pgsql-13/lib/postgis-3.so
-rwxr-xr-x 1 root root 1076312 May 26 2021 postgis-3.so
-rwxr-xr-x 1 root root 858608 May 26 2021 postgis_raster-3.so
-rwxr-xr-x 1 root root 435648 May 26 2021 postgis_sfcgal-3.so
-rwxr-xr-x 1 root root 564928 May 26 2021 postgis_topology-3.so
lrwxrwxrwx 1 root root 37 Aug 18 02:35 rtpostgis-2.4.so <http://2.4.so> -> /usr/pgsql-13/lib/postgis_raster-3.so
Thanks,
Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220818/cf9f7bfe/attachment-0001.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220818/cf9f7bfe/attachment-0001.obj>
