[postgis-devel] The index is not optimal. To optimize it, contact a developer, or try to use the column as the second one in the CREATE INDEX command.
Sandro Santilli
strk at kbt.io
Fri Feb 4 02:53:36 PST 2022
Have you ever seen the message in the subject? I'm getting many of
these messages while loading a topology:
DEBUG: picksplit method for column 1 of index "edge_gist" failed
HINT: The index is not optimal. To optimize it, contact a developer,
command.
The index is:
"edge_gist" gist (geom)
--strk;
