[postgis-devel] spatial_ref_sys view
Even Rouault even.rouault at spatialys.com
Fri Feb 4 12:12:22 PST 2022
> When you talk about speed, in which cases do you think querying
> spatial_ref_sys is going to be a problem ? Aren't we caching the
> lookups ?
The OGR PostgreSQL driver can issue a "SELECT srid FROM spatial_ref_sys
WHERE srtext = %s" request in a fallback case, when creating a new table
with a CRS which has no known (auth_name, auth_srid) tuple.
Retrieving all the CRS from all authorities (mostly EPSG and ESRI. other
authorities are marginal) from the database of PROJ master and getting
their WKT definition takes  ~ 1.6 sec with the below program.
Restricting it to EPSG is ~ 600 ms , and ESRI ~ 900 ms (I suspect the
longer time for ESRI is due to the fact of having to massage ESRI WKT to
"standard" WKT using EPSG object names, involving additional lookups in
the alias table)
Even
#include <proj.h>
#include <stdio.h>
void get_from_authority(PJ_CONTEXT* ctxt, const char* auth_name)
     PROJ_STRING_LIST list = proj_get_codes_from_database(ctxt,
auth_name, PJ_TYPE_CRS, 0);
     for(char** iter = list; iter && *iter; ++iter)
         PJ* pj = proj_create_from_database(ctxt, auth_name, *iter,
PJ_CATEGORY_CRS, 0, 0);
         const char* wkt = proj_as_wkt(ctxt, pj, PJ_WKT2_2019, NULL);
         //printf("%s\n", wkt);
         proj_destroy(pj);
     proj_string_list_destroy(list);
int main(int argc, char** argv)
     PJ_CONTEXT* ctxt = proj_context_create();
     if( argc == 2 )
         get_from_authority(ctxt, argv[1]);
     else
         PROJ_STRING_LIST listAuth =
proj_get_authorities_from_database(ctxt);
         for(char** iterAuth = listAuth; iterAuth && *iterAuth; ++iterAuth)
             printf("%s\n", *iterAuth);
             get_from_authority(ctxt, *iterAuth);
         proj_string_list_destroy(listAuth);
     proj_context_destroy(ctxt);
     return 0;
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
http://www.spatialys.com
