[postgis-devel] PSC Vote: Make spatial_ref_sys as a view
Paul Ramsey
pramsey at cleverelephant.ca
Mon Feb 7 14:05:20 PST 2022
I still feel like we're doing heart surgery here for a very thinly populated user population. I would still just rather not do this. I am not seeing the outcry and user demand for this, and it's not a "use it if you want it, ignore it if you don't" kind of a thing.
Anyways, I wanted to at least try it, so I got the branch and did an upgrade.
createdb srs
psql srs
-- old version
create extension postgis version '3.2.1dev';
-- user-generated srs
insert into spatial_ref_sys select 200000 as srid, auth_name, auth_srid, srtext, proj4text from spatial_ref_sys where srid = 900913;
-- master built from spatial-ref-sys-view branch
alter extension postgis update to '3.3.0dev';
select srid from spatial_ref_sys_user;
4893
6319
6782
200000
The upgrade proceeded silently and did drop my srs into the right place, very nice. I'm a bit baffled why it picked up those others though, and they are also in the system table.
select srid from spatial_ref_sys_postgis where srid in (4893, 6319, 6782, 200000);
4893
6319
6782
Anyways, I'm a -0 shading into a negative one unless you trot out some users who will worship this change.
P.
> On Feb 4, 2022, at 2:16 PM, Regina Obe <lr at pcorp.us> wrote:
> I'm calling for a formal vote to put into master the hard work that Sandro
> has already done in -
> https://git.osgeo.org/gitea/postgis/postgis/src/branch/spatial-ref-sys-view
> +1 from me.
> Reason:
> We need a clean way to update/insert new spatial_ref_sys entries without
> accidentally messing up ones that users explicitly put in or update.
> Right now we have a bug that we are not updating spatial_ref_sys at all so
> upgrades are incomplete without users manually filtering thru
> spatal_ref_sys.sql and adding the ones they are missing.
> We had hoped to use ranges, but users get those from various sources, so I
> think the range idea is impractical for many users.
> To summarize the plan:
> 1) spatial_ref_sys will become a view with INSERT/UPDATE/DELETE instead of
> triggers
> And will be a union of spatial_ref_sys_postgis and spatial_ref_sys_user
> which I will describe in next bullets.
> The entries in spatial_ref_sys_user override those in
> 2) spatial_ref_sys_postgis will have all the entries we currently have
> For upgrades
> TRUNCATe spatial_ref_sys_postgis
> INSERT spatial_ref_sys_postgis
> 3) User entries will be in spatial_ref_sys_user
> 4) For backward compatibility if a user inserts an entry in the
> spatial_ref_sys view, the INSERT will be redirected to
> 5) The clean idea - we can change later, but plan would be any entries in
> spatial_ref_sys_user that are exactly the same as the ones in
> spatial_ref_sys_postgis would be removed.
> Presumably most of these were added cause our spatial_ref_sys was out of
> date and people needed newer ones.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
