[postgis-devel] Postgis 3.3 extension upgrade on AWS RDS Postgres 13.3
Sandro Santilli
strk at kbt.io
Wed Feb 16 05:26:52 PST 2022
On Tue, Feb 15, 2022 at 12:55:53PM -0500, Regina Obe wrote:
> > In 3.3 I had `postgis_extensions_upgrade()` do the UPDATE to pg_extension.
> > If that's going to error out, under AWS, while the previous approach worked,
> > we'll probably want to revert that change.
> I suspect it will work, but I'll confer with Amazon RDS staff.
Thanks.
> CREATE EXTENSION / ALTER EXTENSION is run by a real super user rdsadmin or some such thing.
> For the brief period that people run those commands they are doing it as a real super user.
The postgis_extensions_upgrade() would run OUTSIDE of alter extension
--strk;
