[postgis-devel] out-of-tree?
Regina Obe
lr at pcorp.us
Wed Feb 16 09:35:38 PST 2022
> > >> mkdir postgis-build
> > >> cd postgis-build
> > >> ../postgis-git/configure ... etcetc ...
> > >> make
> > > It's not documented because should be common way.
> > The build doco in the README.postgis still assumes in-tree building. I
> didn't check the docbook.
> There's no plan to *drop* support for in-tree building, just a movement
> toward *ALSO* supporting out-of-tree building (which is not fully working
> yet, for some make targets).
> --strk;
[Regina Obe]
So you going to document the out-of-tree building once it's completely
working ?
