[postgis-devel] PSC Vote: Approve RFC-5 Core Contributor Guidelines
Regina Obe
lr at pcorp.us
Mon Feb 28 20:25:54 PST 2022
Oh and forgot about pgPointCloud so added that too.
Ogrfdw I was thinking of adding but it doesn’t rely on PostGIS directly.
Sent: Monday, February 28, 2022 11:23 PM
To: 'PostGIS Development Discussion' <postgis-devel at lists.osgeo.org>
Subject: RE: [postgis-devel] PSC Vote: Approve RFC-5 Core Contributor Guidelines
Imre,
All very good points. I’ve amended based on your comments.
1) I’ve added a section == Projects under PostGIS umbrella ==
and included Docker PostGIS, PostGIS Java, and PostGIS Workshop
2) In the Relationships with Other Projects
I’ve added sfcgal to the upstream projects section
and mobilitydb to the downstream list
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Imre Samu
Sent: Monday, February 28, 2022 10:55 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org> >
Subject: Re: [postgis-devel] PSC Vote: Approve RFC-5 Core Contributor Guidelines
Based on the contents ( https://trac.osgeo.org/postgis/wiki/DevWikiComitGuidelines )
2 small comments:
1.)
to the "Relationship with other Projects"
- probably the https://mobilitydb.com/ can be added. ( "MobilityDB is a geospatial trajectory data management & analysis platform, built on PostgreSQL and PostGIS." )
2.)
And just a side comment:
I see mentioning:
- Core developers
- Primary repo
- Relationship with other Projects
But I don't see the relationship with the "non-core projects under the Postgis umbrella",
like the https://github.com/postgis/docker-postgis project
imho: postgis_project=true AND core_project=false AND matured=false
Kind regards,
Imre
( docker-postgis contributor )
Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > ezt írta (időpont: 2022. febr. 19., Szo, 23:04):
I've made a number of changes to
to hopefully modernize it. Key changes
1) Get rid of references to our old model -- such as keeping an authors.git
/ authors.svn , spike branches, and updating CREDITS file
2) Replace most references of Committer with Core Contributor or Contributor
(to address strk's sensitivities)
2) Change the term Developer to Contributor to be in agreement with our
documentation and to better value contributions beyond code.
3) Updates to how tickets and pull requests should be tagged.
5) Rename it from "PostGIS Commiter Guidelines" to "Core Contributor
Guidelines"
If everyone is okay with the changes, I'll mark as Approved.
Thanks,
Regina
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220228/da943c2b/attachment.html>
