[postgis-devel] autoconf versions
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jan 7 15:09:02 PST 2022
On Fri, Jan 7, 2022 at 3:01 PM Sandro Santilli <strk at kbt.io> wrote:
> On Thu, Jan 06, 2022 at 01:50:25PM -0800, Paul Ramsey wrote:
> > The configuration it generates seems to run and build for me here,
> > but obviously this is our most platform-dependent piece so some extra
> > tests before I drop it on master would be nice.
> Tested on my main development machine running autoconf-2.69 and
> while I had no warnings at ./autogen.sh && ./configure time, I got
> this on `make`:
> libtool: error: cannot find the library '/usr/lib/x86_64-linux-gnu/libsqlite3.la' or unhandled argument '/usr/lib/x86_64-linux-gnu/libsqlite3.la'
> Am I the only one ?
> I'm using libtool (GNU libtool) 2.4.6
Not seeing anything like that here. That's really kind of odd, isn't
it? I mean, sqlite3 would be in the proj dep chain, but it's being
looked for in the postgis build?
P.
> --strk;
