[postgis-devel] GiST Sorting
Darafei "Komяpa" Praliaskouski me at komzpa.net
Sun Jan 9 06:11:47 PST 2022
Hi everyone,
After several weeks of research, testing and experiments we believe we
found a solution that does not cause the select performance degradation (or
sometimes brings profit) and still builds the index faster using the
sorting build method.
The patch is posted on pgsql-hackers by Aliaskandr Kalenik in this thread:
https://www.postgresql.org/message-id/CAHqSB9jqtS94e9%3D0vxqQX5dxQA89N95UKyz-%3DA7Y%2B_YJt%2BVW5A%40mail.gmail.com
Patch on commitfest:
https://commitfest.postgresql.org/36/3487/
Sergei Shoulbakov implemented the benchmark to prove the effect. Results
and notes are posted here:
https://www.postgresql.org/message-id/3aa6ba30-e9d8-10ef-753f-8deea5f196d0%40kontur.io
We need your help to get it reviewed and merged to get the benefits for
everyone in PG15.
Darafei.
On Fri, Dec 3, 2021 at 10:19 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> This is done at
> https://github.com/postgis/postgis/commit/d8976c0d2f6b8906b583f24e98fba2ef92fb1277
> On Fri, Dec 3, 2021 at 10:37 AM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > Nevermind, I found the secret incantation:
> > alter operator family gist_geometry_ops_2d using gist drop function 11
> (geometry);
> > alter operator family gist_geometry_ops_2d using gist add function 11
> (geometry) geometry_gist_sortsupport_2d (internal);
> > P.
> > > On Dec 2, 2021, at 12:57 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > > Ding ding!
> > > I can strip the sort support function out of the default opclass, but
> > > we don't have any way to add it back in, except with a direct
> > > alteration of the system tables. If we're OK with that, I will figure
> > > out the magic SQL incantation so we can document it, and strip the
> > > sort support function from the opclass.
> > > P
> > > On Wed, Dec 1, 2021 at 1:10 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > >> So about this plan, I don't see the ALTER OPERATOR CLASS recipe that
> can do the thing we want.
> > >> https://www.postgresql.org/docs/14/sql-alteropclass.html
> > >> What's the magic incantation?
> > >>> On Dec 1, 2021, at 8:30 AM, Regina Obe <lr at pcorp.us> wrote:
> > >>>> Initially there was a patch in patchset making user specify sorting
> function
> > >>>> during CREATE INDEX ON table USING gist(column) WITH
> > >>>> (sortfunction=zcurve). But everyone said that it's unnessecary
> complication and
> > >>>> we just made the function part of the opclass.
> > >>>> But sorting build was not meant to be default!
> > >>>> I'm going to work on this in December, so let's figure out what
> exactly do we
> > >>>> want from PostgreSQL 15?
> > >>>> I'm planning to work on:
> > >>>> 1. Fix the concurrency problem in IndexOnlyScan that Peter G.
> pointed out [0]
> > >>>> This will further slow down GiST queries a little, sorry.
> > >>>> 2. Sorting items within leaf page in tid order, not provided
> sorting function.
> > >>>> 3. Make better splits of leaf pages. Currently we choose how to
> split leaf pages
> > >>>> solely by sorting function. I want to use split function too. This
> will consume
> > >>>> slightly more memory, but will build better index.
> > >>>> Do we need some functionality to easily enable\disable sorting
> build? I think
> > >>>> chances are very high that we can make it better. But it still will
> be neither
> > >>>> perfect, nor better than buffered build.
> > >>>> Thanks!
> > >>>> Best regards, Andrey Borodin.
> > >>> [Regina Obe]
> > >>> I don't think I was in this discussion about CREATE INDEX ON table
> > >>> What was the unnecessary complication?  Was it deemed "user-facing"
> too complicated
> > >>> or "under the hood" too complicated.
> > >>> For user-facing I don't see it as too complicated.  Granted it is a
> bit extra.
> > >>> But if it is deemed always not the absolute best, I feel a configure
> option is fine.
> > >>> It's only giving users redundant equally good options that I would
> consider too complicated.
> > >>> _______________________________________________
> > >>> postgis-devel mailing list
> > >>> postgis-devel at lists.osgeo.org
> > >>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220109/b552ec0b/attachment.html>
