[postgis-devel] GiST Sorting
Giuseppe Broccolo g.broccolo.7 at gmail.com
Wed Jan 12 16:09:40 PST 2022
Hi Paul,
I have a question: I see you used the function `gist_stat` to inspect the
GiST indexes which is quite useful to check the overlaps between the boxes
in the leaf nodes. I would like to use it as well,
but unfortunately I wasn't able to find any reference beside the gevel repo
<http://www.sai.msu.su/~megera/wiki/Gevel>. Could you tell me which
extension you used to get this function?
Thanks in advance,
Giuseppe.
Il giorno mar 11 gen 2022 alle ore 21:17 Paul Ramsey <
pramsey at cleverelephant.ca> ha scritto:
> > On Jan 11, 2022, at 12:52 PM, Giuseppe Broccolo <g.broccolo.7 at gmail.com>
> wrote:
> > Hi Darafei,
> > On Sun, 9 Jan 2022, 14:12 Darafei "Komяpa" Praliaskouski, <me at komzpa.net>
> wrote:
> > Hi everyone,
> > After several weeks of research, testing and experiments we believe we
> found a solution that does not cause the select performance degradation (or
> sometimes brings profit) and still builds the index faster using the
> sorting build method.
> > The patch is posted on pgsql-hackers by Aliaskandr Kalenik in this
> thread:
> https://www.postgresql.org/message-id/CAHqSB9jqtS94e9%3D0vxqQX5dxQA89N95UKyz-%3DA7Y%2B_YJt%2BVW5A%40mail.gmail.com
> > Patch on commitfest:
> > https://commitfest.postgresql.org/36/3487/
> > Sergei Shoulbakov implemented the benchmark to prove the effect. Results
> and notes are posted here:
> https://www.postgresql.org/message-id/3aa6ba30-e9d8-10ef-753f-8deea5f196d0%40kontur.io
> > We need your help to get it reviewed and merged to get the benefits for
> everyone in PG15.
> > That's cool! What can we do to help?
> Well, one thing we definitely need is to compare the performance of the
> patched sortsupport method to the vanilla index build, across a variety of
> inputs and workloads. My example data was interesting, as a heterogenous
> set of data (differing object spatial sizes, differing densities across the
> data set) but there's lot of other different data that should be
> benchmarked. Get your favourite data sets and see what happens. Tests on
> small tables might also have some quirks that don't show up in large table
> tests. Harder to measure, but worth measuring.
> ATB,
> P
> > Giuseppe.
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220113/9ee3736d/attachment.html>
