[postgis-devel] ST_Subdivide Defaults
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jan 21 09:45:41 PST 2022
Jokes on me then, the default in the SQL file is still 256.
CREATE OR REPLACE FUNCTION ST_Subdivide(geom geometry, maxvertices integer DEFAULT 256, gridSize float8 DEFAULT -1.0)
P.
> On Jan 21, 2022, at 9:42 AM, Darafei Komяpa Praliaskouski <me at komzpa.net> wrote:
> You did that some years ago and ignored my note to update docs: https://github.com/postgis/postgis/commit/feac7c6ed625bea34de847605a590abdb627bd13
> пт, 21 сту 2022, 20:35 карыстальнік Paul Ramsey <pramsey at cleverelephant.ca> напісаў:
> A user was talking about how much faster ST_Subdivide made their query, and their example was materializing the subdivided geometries into a table, building an index, and then using that downstream.
> Here's the thing: the default numVertices of ST_Subdivide is 256. Which (256 * 2 * 8 = 4096) is half of a full page, but actually kind of close to the TOAST threshold. At a minimum with standard storage defaults, it'll be getting compressed inline, if not actually TOASTed still. Which will hurt performance.
> I was thinking that a 128 or even 96 point default might make a lot more sense. At 128 vertices (2048 bytes) we're still flirting with inline compression, so maybe 96 (1536b) or even 64 vertices (1024b) would be best.
> In general, it seems like a missed upportunity to have something shredding down geometries but still be over-running the TOAST thresholds, that we know have performance implications, when the whole point of the shredding is improved performance.
> Thoughts?
> P
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
