[postgis-devel] Upgrade PostGIS from 2.5.4 to 3.1.2
Regina Obe
lr at pcorp.us
Mon Jan 24 11:06:40 PST 2022
I think I ran into this issue too though I was doing a pg_upgrade from 9.6 to 11 at the same time.
The issue is since both ship and overlapping set of files, they can’t cleanly coexist.
The below should work.
Uninstall postgis25_11 package
Install the postgis31_11 package
Symlink the old names to the new libraries
ln -s /usr/pgsql-11/lib/postgis-3.so /usr/pgsql-11/lib/postgis-2.5.so
ln -s /usr/pgsql-11/lib/postgis_raster-3.so /usr/pgsql-11/lib/rtpostgis-2.5.so
#if you are not using these libraries, you can skip this step
ln -s /usr/pgsql-11/lib/postgis_topology-3.so /usr/pgsql-11/lib/postgis_topology-2.5.so
ln -s /usr/pgsql-11/lib/address_standardizer-3.so /usr/pgsql-11/lib/address_standardizer-2.5.so
ln -s /usr/pgsql-11/lib/address_standardizer-3.so /usr/pgsql-11/lib/address_standardizer.so
#On your databases
SELECT postgis_full_version();
Should show something to the effect you have 2.5 scripts but are running postgis-3
ALTER EXTENSION postgis UPDATE;
SELECT postgis_extensions_upgrade();
SELECT postgis_extensions_update();
-- if not using raster, you can do this
DROP EXTENSION postgis_raster;
#after you are done upgrading your dbs, you can drop the symlinks e.g.
rm /usr/pgsql-11/lib/rtpostgis-2.5.so
rm /usr/pgsql-11/lib/postgis-2.5.so
rm /usr/pgsql-11/lib/postgis_topology-2.5.so
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nikhil Shetty
Sent: Monday, January 24, 2022 1:48 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>; postgis-users at lists.osgeo.org
Subject: [postgis-devel] Upgrade PostGIS from 2.5.4 to 3.1.2
Hi Team,
I am looking for a way to upgrade postgis on postgresql 11 from 2.5.4 to 3.1.2
I am getting below error when doing though yum
Transaction check error:
file /usr/pgsql-11/share/extension/address_standardizer.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/address_standardizer.sql from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/address_standardizer_data_us.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/postgis.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/postgis_sfcgal.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/postgis_tiger_geocoder.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/postgis_topology.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/bin/pgsql2shp from install of postgis31_11-client-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-client-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/bin/raster2pgsql from install of postgis31_11-client-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-client-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/bin/shp2pgsql from install of postgis31_11-client-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-client-2.5.4-1.rhel7.x86_64
I have seen the document for 'Hard Upgrade' but that is unfortunately a long route to take for critical databases.
Postgresql Version - 11.7
OS - RHEL 7.9
Full Version Details -
PostgreSQL 11.7 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-39), 64-bit POSTGIS="2.5.4" [EXTENSION] PGSQL="110" GEOS="3.8.1-CAPI-1.13.3" PROJ="Rel. 7.0.0, March 1st, 2020" GDA
L="GDAL 3.0.4, released 2020/01/28" LIBXML="2.9.1" LIBJSON="0.11" LIBPROTOBUF="1.0.2" RASTER
Thanks and Regards,
Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220124/58a302c3/attachment.html>
