[postgis-devel] Upgrade PostGIS from 2.5.4 to 3.1.2
Regina Obe
lr at pcorp.us
Tue Jan 25 10:44:12 PST 2022
Uninstalling will cause downtime if any postgis functions are in active use at the time of uninstall.
However if you install and symlink fast enough, you shouldn’t have much downtime, if any at all. Probably under 10 minutes.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nikhil Shetty
Sent: Monday, January 24, 2022 2:17 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Cc: postgis-users at lists.osgeo.org
Subject: Re: [postgis-devel] Upgrade PostGIS from 2.5.4 to 3.1.2
Hi Regina,
Thank you for sharing the steps.Yes, we are upgrading the database as well from 11.7 to 13.4.
I saw the steps you shared and I will give it a try.
Does uninstalling postgis25_11 have any impact on a running Postgres database that is using postgis25_11 functions?? Wanted to know which step will cause a downtime to the application apart from the database upgrade step.
Thanks and Regards,
Nikhil
On Tue, 25 Jan 2022 at 12:36 AM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I think I ran into this issue too though I was doing a pg_upgrade from 9.6 to 11 at the same time.
The issue is since both ship and overlapping set of files, they can’t cleanly coexist.
The below should work.
Uninstall postgis25_11 package
Install the postgis31_11 package
Symlink the old names to the new libraries
ln -s /usr/pgsql-11/lib/postgis-3.so /usr/pgsql-11/lib/postgis-2.5.so <http://postgis-2.5.so>
ln -s /usr/pgsql-11/lib/postgis_raster-3.so /usr/pgsql-11/lib/rtpostgis-2.5.so <http://rtpostgis-2.5.so>
#if you are not using these libraries, you can skip this step
ln -s /usr/pgsql-11/lib/postgis_topology-3.so /usr/pgsql-11/lib/postgis_topology-2.5.so <http://postgis_topology-2.5.so>
ln -s /usr/pgsql-11/lib/address_standardizer-3.so /usr/pgsql-11/lib/address_standardizer-2.5.so <http://address_standardizer-2.5.so>
ln -s /usr/pgsql-11/lib/address_standardizer-3.so /usr/pgsql-11/lib/address_standardizer.so
#On your databases
SELECT postgis_full_version();
Should show something to the effect you have 2.5 scripts but are running postgis-3
ALTER EXTENSION postgis UPDATE;
SELECT postgis_extensions_upgrade();
SELECT postgis_extensions_update();
-- if not using raster, you can do this
DROP EXTENSION postgis_raster;
#after you are done upgrading your dbs, you can drop the symlinks e.g.
rm /usr/pgsql-11/lib/rtpostgis-2.5.so <http://rtpostgis-2.5.so>
rm /usr/pgsql-11/lib/postgis-2.5.so <http://postgis-2.5.so>
rm /usr/pgsql-11/lib/postgis_topology-2.5.so <http://postgis_topology-2.5.so>
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org <mailto:postgis-devel-bounces at lists.osgeo.org> ] On Behalf Of Nikhil Shetty
Sent: Monday, January 24, 2022 1:48 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org> >; postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: [postgis-devel] Upgrade PostGIS from 2.5.4 to 3.1.2
Hi Team,
I am looking for a way to upgrade postgis on postgresql 11 from 2.5.4 to 3.1.2
I am getting below error when doing though yum
Transaction check error:
file /usr/pgsql-11/share/extension/address_standardizer.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/address_standardizer.sql from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/address_standardizer_data_us.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/postgis.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/postgis_sfcgal.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/postgis_tiger_geocoder.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/share/extension/postgis_topology.control from install of postgis31_11-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/bin/pgsql2shp from install of postgis31_11-client-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-client-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/bin/raster2pgsql from install of postgis31_11-client-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-client-2.5.4-1.rhel7.x86_64
file /usr/pgsql-11/bin/shp2pgsql from install of postgis31_11-client-3.1.2-1.rhel7.x86_64 conflicts with file from package postgis25_11-client-2.5.4-1.rhel7.x86_64
I have seen the document for 'Hard Upgrade' but that is unfortunately a long route to take for critical databases.
Postgresql Version - 11.7
OS - RHEL 7.9
Full Version Details -
PostgreSQL 11.7 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-39), 64-bit POSTGIS="2.5.4" [EXTENSION] PGSQL="110" GEOS="3.8.1-CAPI-1.13.3" PROJ="Rel. 7.0.0, March 1st, 2020" GDA
L="GDAL 3.0.4, released 2020/01/28" LIBXML="2.9.1" LIBJSON="0.11" LIBPROTOBUF="1.0.2" RASTER
Thanks and Regards,
Nikhil
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220125/c874d592/attachment.html>
