[postgis-devel] ST_ConcaveHull in GEOS
Martin Davis mtnclimb at gmail.com
Tue Jan 25 16:04:30 PST 2022
For some more background on the (potential) new Concave Hull algorithm,
see:
https://github.com/locationtech/jts/pull/823
http://lin-ear-th-inking.blogspot.com/2022/01/concave-hulls-in-jts.html
On Tue, Jan 25, 2022 at 2:38 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Hey all,
> The native ST_ConcaveHull in GEOS is in GEOS main now, so I have hooked it
> up into PostGIS in this branch
> https://github.com/pramsey/postgis/tree/master-concavehull
> Under this function for now.
> CREATE OR REPLACE FUNCTION _ST_GEOSConcaveHull(
>   geom geometry,
>   area_ratio float8,
>   allow_holes boolean DEFAULT false)
> I would like to just flip the old ST_ConcaveHull out and replace it with
> the new one, for folks with GEOS 3.11+, but I figured an interval to look
> at them side by side for a while on a test branch might be appreciated.
> Currently the case of point inputs is worth looking at. Polygon inputs that
> respect the polygon are (hull doesn't cross interior of input polygon)
> coming down the line.
> P
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220125/b64aa586/attachment.html>
