[postgis-devel] PSC Vote: Get rid of micro in PostGIS Extension scripts (and comments from others)
Bruce Rindahl
bruce.rindahl at gmail.com
Tue Jun 7 07:18:46 PDT 2022
Depends on the package. To install PostgreSQL as a windows service takes
admin rights (EDB). To start PostgreSQL via a command (pg_ctl) each time
does not.
On Tue, Jun 7, 2022 at 8:01 AM Sandro Santilli <strk at kbt.io> wrote:
> On Tue, Jun 07, 2022 at 07:20:32AM -0600, Bruce Rindahl wrote:
> > Windows does support symbolic links but you need admin privileges to
> create
> > them. I believe you need admin rights to install PostgreSQL but not
> > PostGIS.
> This is very interesting. How come you don't need admin rights to
> install PostGIS ? Installing PostGIS implies writing files to the
> "extension" directory of PostgreSQL install, is that considered safe
> by the Windows security model ? Does that imply installing PostgreSQL
> in a non-system directory ?
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220607/2db0c335/attachment.htm>
