[postgis-devel] CI on Linux ARM64
Martin Grigorov
martin.grigorov at gmail.com
Wed Mar 30 05:26:40 PDT 2022
Hello PostGIS developers,
I've noticed that there are no builds on Linux ARM64 at the moment.
https://trac.osgeo.org/postgis/ says that the build on Berrie64 is failing.
But https://debbie.postgis.net/computer/berrie64/ says:
"This agent is offline because Jenkins failed to launch the agent process
on it.
Projects tied to berrie64
None"
I see that there is another ARM64 agent at
https://debbie.postgis.net/computer/armmie/ but again no projects use it.
Is this is a known issue ?
Kind regards,
Martin
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220330/404178d1/attachment.html>
