[postgis-devel] GEOSLineMergeDirected
Martin Davis mtnclimb at gmail.com
Tue May 24 16:28:54 PDT 2022
I'll open a ticket for this - better to track discussion.
https://trac.osgeo.org/postgis/ticket/5161
On Tue, May 24, 2022 at 12:39 PM Regina Obe <lr at pcorp.us> wrote:
> It won’t cause any problems if you overload it rather than add a default
> arg.
> The default arg is cleaner, since we won’t have an additional function to
> contend with.
> The main danger with adding a default arg is anybody who is using
> ST_LineMerge in views will have some upgrade issues.  Since adding a
> default arg requires dropping the old version.
> Though Sandro made some adjustments to partly resolve that.
> https://trac.osgeo.org/postgis/ticket/5033
> It renames the old function (assuming you put in the right availability
> comments) and then if there are views dependent on the old (because views
> references the oid of the function, and not the function name),  then the
> upgrade will be in an incomplete upgrade state (will just have those
> dangling old names)
> https://trac.osgeo.org/postgis/changeset/3d947448b9c939b321bc22b85c719845722ecc3d/git
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Martin Davis
> *Sent:* Tuesday, May 24, 2022 1:57 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> *Subject:* [postgis-devel] GEOSLineMergeDirected
> This is now merged in GEOS (for the upcoming 3.11).
> How should it be exposed in PostGIS?  Nicest might be an optional
> "directed=false" flag on ST_LineMerge.  But will that cause
> upgrade problems?
> Less nice IMO would be a new function ST_LineMergeDirected.
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220524/955604c5/attachment.htm>
