[postgis-devel] build failure in pkgsrc, deep in pgxs
    Greg Troxel
    gdt at lexort.com
    Sat Oct  8 07:14:59 PDT 2022
Greg Troxel <gdt at lexort.com> writes:
>   ---- Making install in topology
>   gmake[2]: Entering directory '/tmp/databases/postgresql-postgis2/work/postgis-3.3.1/topology'
>   /bin/sh ../config/install-sh -c -d '/tmp/databases/postgresql-postgis2/work/.destdir/usr/pkg/lib/postgresql'
>   /bin/sh: Can't open ../config/install-sh
This seems to be because pgxs ends up with
  install_sh = $(SHELL) $(top_srcdir)/config/install-sh -c
and
  MKDIR_P = ${SHELL} ${top_srcdir}/config/install-sh -c -d
and when it tries to use it, top_srcdir is not defined, because topology
does not set it.
So:
  is my postgresql build broken, and if so why and how?
  is topology/Makefile.in broken because it uses pgxs and does not
  define top_srcdir?
  something else?
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20221008/2bc27faa/attachment.sig>
