[postgis-devel] Upgrade paths (again)
Greg Troxel
gdt at lexort.com
Wed Sep 14 05:31:11 PDT 2022
Sandro Santilli <strk at kbt.io> writes:
>> > The package managers I know of have the ability to run a script before
>> > or after doing "things". Don't knot the details but they do things
>> > like setting symlinks or starting interactive configuration sessions.
>> > They may as well run that script.
>> Yes, scripts can be run, but I view using that facility as an negative,
>> rather than just producing the right bits at package build time.
> There is no "right bits" as those depend on the status of the machine.
> What's "right" depends on what versions users need to upgrade from,
> thus the script (which can only partially determine that, in its
> current state).
I see. Well, my view is that in packaging we try to push as many things
into "build", and do as little as possible/reasonable at install time.
And, at package installation time, it is quite possible that pgsql is
not running, and the package manager probably doesn't have database
privs.
>> And, at least in pkgsrc, running a de-installation script won't have
>> available files (or any other information) from the new package.
> I don't understand this last statement.
What I meant is that upgrading consists of
- running a before-deinstallation script, usually empty
- removing the files that the package installs, except config files
meant to be edited by the user (in /usr/pkg/etc usually)
- installing the files from the new package
- running an after-installation script
This is the same as pkg_delete/pkg_add, except that when upgrading foo,
then for things bar that depend on foo, bar's dependencies are repointed
to the new foo, and the removal of foo isn't blocked with a "bar depends
on foo; can't delete foo without -f" message.
So the before-deinstallation script doesn't know about the new package;
it is a component of the old package. It doesn't know about upgrades,
just that the package is being removed.
I think we're somewhat running into "databases are hard and need a DBA".
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20220914/f58975a3/attachment.sig>
