[postgis-devel] cost of some functions (e.g. st_within) might be too high after 3ddc11483b
Tomas Vondra tomas.vondra at 2ndquadrant.com
Sat Sep 24 15:40:17 PDT 2022
On 9/24/22 21:40, Darafei "Komяpa" Praliaskouski wrote:
> Hi,
> Bitmap scans in the plans are usually a sign of a system's
> random_page_cost being too high or/and work_mem being too low.
Well, work_mem is 2GB and random_page_cost is 4 (i.e. default). Maybe
random_page_cost could have been lower, say 2, but that does not really
solve anything because that cost was included in the original cost ~100k
already, which now increased to 1.1M. The increase alone would be
sufficient to make this much more expensive than bitmap index scan, and
AFAICS that has nothing to do with random_page_cost.
> In general, I'd say it is more about incorrect costing of Bitmap scans
> in postgres itself - there is an assumption buried deep into it that
> bitmap scan with per-page bitmap and with per-tuple bitmap will cost
> similar, while actually it should be st_within_cost*n_tuples_per_page
> times higher. This can sometimes be fought by higher work_mem but if
> someone gets this addressed upstream this will be nice.
I don't think this applies, because with work_mem=2GB we should have
per-tuple bitmap. In fact, this is not dealing with that many tuples so
even lower work_mem values should be enough.
> For costing of postgis functions, there was a research that measuret
> real cost, unlike the rest of postgres where costs are
> guesswork: https://github.com/postgis/postgis/pull/104
> <https://github.com/postgis/postgis/pull/104>
I don't find that pull pull request discussion convincing - it discusses
which functions should cost more than other functions, yet what the
commit 3ddc11483b is setting most of the costs to 10000 (which is not
mentioned in the discussion at all).
Moreover, the commit talks about inlining, which is not discussed in the
PR at all, and only enables the higher costs on PG12. But that was
released in 2019, and the discussion is from 2017 ...
regards
Tomas Vondra
EnterpriseDB: http://www.enterprisedb.com
The Enterprise PostgreSQL Company
