[postgis-devel] Error Upgrading PostGIS 2.5.4 to 3.1.2
Nikhil Shetty
nikhil.dba04 at gmail.com
Fri Apr 14 00:59:02 PDT 2023
Hi Team,
We are running on PostgreSQL v10.12 and we are in the process to upgrade it
to v13. We are using PostGIS v2.5.4 on v10.12.
We want to upgrade PostGIS as well to 3.1.2. We plan to follow below
approach
1. Upgrade PostGIS from 2.5.4 to 3.1.2 on PostgreSQL 10.12
2. Upgrade PostgreSQL 10.12 to 13
When performing step 1, we are getting below error
geo=# alter extension postgis update to '3.1.2';
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
ERROR: could not access file "$libdir/postgis-2.5": No such file or
directory
CONTEXT: PL/pgSQL function _postgis_drop_function_if_needed(text,text)
line 6 at FOR over SELECT rows
geo=# SELECT postgis_extensions_upgrade();
postgis_raster;
directory
SQL statement "ALTER EXTENSION postgis UPDATE TO "3.1.2";"
PL/pgSQL function postgis_extensions_upgrade() line 22 at EXECUTE
We removed the old 2.5.4 packages and installed 3.1.2
ls -l /usr/pgsql-10/lib | grep postgis
-rwxr-xr-x 1 root root 1047128 Jun 29 2021 *postgis*-3.so
-rwxr-xr-x 1 root root 850416 Jun 29 2021 *postgis*_raster-3.so
-rwxr-xr-x 1 root root 435656 Jun 29 2021 *postgis*_sfcgal-3.so
-rwxr-xr-x 1 root root 565008 Jun 29 2021 *postgis*_topology-3.so
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230414/fdd18770/attachment.htm>
