[postgis-devel] Error Upgrading PostGIS 2.5.4 to 3.1.2
Nikhil Shetty nikhil.dba04 at gmail.com
Mon Apr 17 02:48:50 PDT 2023
Hi Sandro,
Old error is gone after the workaround( I had to add a hyphen in 2.5 in sed
command).
I see we are getting different error now and looks like there are a lot of
objects dependent on functions which are being dropped.
db1=# alter extension postgis update;
WARNING:  unpackaging raster
WARNING:  PostGIS Raster functionality has been unpackaged
HINT:  type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
ERROR:  cannot drop function st_buffer(geometry,double precision) because
other objects depend on it
DETAIL:  view xxxxx depends on function st_buffer(geometry,double precision)
HINT:  Use DROP ... CASCADE to drop the dependent objects too.
db1=# drop view xxxxx;
DROP VIEW
geo=# alter extension postgis update;
postgis_raster;
ERROR:  cannot drop function st_intersection(geometry,geometry) because
DETAIL:  function xxxxx depends on function
view xxxxx depends on function st_intersection(geometry,geometry)
Is there a way to identify the list of objects being dropped? and which all
views/functions depend on these dropped objects?
Thanks,
Nikhil
On Mon, Apr 17, 2023 at 2:54 PM Nikhil Shetty <nikhil.dba04 at gmail.com>
wrote:
> Hi Sandro,
> Thank you, I will try the workaround
> BUT I'm wondering: why would you want to upgrade to 3.1.2 when the
> latest PostGIS version in the 3.1 branch is 3.1.8 ?
>  -- We started with the upgrade at a time when 3.1.2 was the latest
> version. We will try to add the newer version in future upgrades.
> Thanks,
> Nikhil
> On Fri, Apr 14, 2023 at 5:08 PM Sandro Santilli <strk at kbt.io> wrote:
>> On Fri, Apr 14, 2023 at 01:29:02PM +0530, Nikhil Shetty wrote:
>> > geo=# alter extension postgis update to '3.1.2';
>> > ERROR:  could not access file "$libdir/postgis-2.5": No such file or
>> directory
>> > We removed the old 2.5.4 packages and installed 3.1.2
>> > ls -l /usr/pgsql-10/lib | grep postgis
>> > -rwxr-xr-x 1 root root 1047128 Jun 29  2021 *postgis*-3.so
>> > -rwxr-xr-x 1 root root  850416 Jun 29  2021 *postgis*_raster-3.so
>> > -rwxr-xr-x 1 root root  435656 Jun 29  2021 *postgis*_sfcgal-3.so
>> > -rwxr-xr-x 1 root root  565008 Jun 29  2021 *postgis*_topology-3.so
>> A quick workaround should be something along these lines:
>>   for f in $('ls' /usr/pgsql-10/lib/*postgis*-3.so); do
>>     l=$(echo "$f" | sed 's/-3\./2.5./')
>>     ln -vs "$f" "$l"
>>   done
>> I'm asking because according to the NEWS file the bug you report
>> was fixed in 3.1.5:
>>   https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.1.5/NEWS#L12
>> --strk;
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230417/df35d4c6/attachment.htm>
