[postgis-devel] Plan release PostGIS 3.4.0 this weekend
Greg Troxel
gdt at lexort.com
Sat Aug 12 03:40:10 PDT 2023
Sebastiaan Couwenberg <sebastic at xs4all.nl> writes:
> Manpages are installed on Linux:
Can somebody point me to how they are installed?
pkgsrc is running configure:
$ ./configure --enable-rpath --datadir=/usr/pkg/share/postgresql/contrib --with-address-standardizer -with-xsldir=/usr/pkg/share/xsl/docbook --x-includes=/usr/X11R7/include --x-libraries=/usr/X11R7/lib --prefix=/usr/pkg --build=x86_64--netbsd --host=x86_64--netbsd --mandir=/usr/pkg/man --enable-option-checking=yes
and config.status has
S["PGSQL_MANDIR"]="/usr/pkg/man"
S["mandir"]="/usr/pkg/man"
Looking at the build log (which is deep in "make install", and which
seems to install everything else):
---- Making install in doc
gmake[2]: Entering directory '/tmp/work/databases/postgresql-postgis2/work/postgis-3.4.0rc2/doc'
/tmp/work/databases/postgresql-postgis2/work/.tools/bin/gmake -f Makefile.comments install
gmake[3]: Entering directory '/tmp/work/databases/postgresql-postgis2/work/postgis-3.4.0rc2/doc'
mkdir -p '/tmp/work/databases/postgresql-postgis2/work/.destdir/usr/pkg/share/postgresql/contrib/postgis-3.4'
/usr/bin/install -c -m 644 postgis_comments.sql raster_comments.sql topology_comments.sql sfcgal_comments.sql '/tmp/work/databases/postgresql-post\
gis2/work/.destdir/usr/pkg/share/postgresql/contrib/postgis-3.4/'
gmake[3]: Leaving directory '/tmp/work/databases/postgresql-postgis2/work/postgis-3.4.0rc2/doc'
gmake[2]: Leaving directory '/tmp/work/databases/postgresql-postgis2/work/postgis-3.4.0rc2/doc'
Reading doc/Makefile.in, on line 551 I see
install: comments-install
and starting on line 496 I see
man-install: man/shp2pgsql.1 man/pgsql2shp.1 man/pgtopo_export.1 man/pgtopo_import.1 man/postgis.1 man/postgis_restore.1
mkdir -p $(DESTDIR)$(mandir)/man1
for f in $^; do \
$(INSTALL_DATA) $$f $(DESTDIR)$(mandir)/man1/`basename $$f`; \
done
and I don't see how the install target depends on the man-install
target. README.postgis documents the install procedure as just 'make
install'.
I added man-install as a dependency of the install target, and now I get
man pages in the destdir.
I'm boggled as to how this works for anyone else. Or maybe the Debian
package worked around this bug long ago by calling man-install in doc
during the install phase?
$NetBSD$
Fix upstream bug not installing man pages.
Sent upstream by email 20230812.
--- doc/Makefile.in.orig 2023-08-12 06:12:40.000000000 +0000
+++ doc/Makefile.in
@@ -548,7 +548,7 @@ docs-install: html-install html-assets-i
docs-uninstall: html-uninstall html-assets-uninstall
rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/README.postgis
-install: comments-install
+install: comments-install man-install
uninstall: comments-uninstall
