[postgis-devel] PostGIS Support Matrix
Peet Whittaker
peet.whittaker at gmail.com
Fri Feb 10 01:37:27 PST 2023
In the PostGIS Support Matrix table (see link below), is there a reason why
all Yes/No values are italicized for PostGIS >=3.2 ?
The "not recommended" text below the table is italicized, which suggests
that these version combinations are not recommended, although I think that
note is leftover from when the table used to contain entries with explicit
"not recommended" notes in (see the obsolete version matrix, also linked
below).
In short, should any of the entries in the current table be italicized, or
is it a mistake/typo?
https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS#PostGISSupportMatrix
https://trac.osgeo.org/postgis/wiki/PostGISObsoleteVersionsMatrix
Kind regards,
Peet W
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230210/8c1477d8/attachment.htm>
