[postgis-devel] Empty for Discussion
Regina Obe
lr at pcorp.us
Fri Feb 10 15:48:58 PST 2023
I get 0 for num geometries, and NULL for ST_GeometryN(..,1)
POSTGIS="3.4.0dev 3.3.0rc2-590-gdd3d8a4cd" [EXTENSION] PGSQL="160" GEOS="3.12.0dev-CAPI-1.18.0" PROJ="7.2.1" LIBXML="2.9.14" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
In theory you are right :) But the answers at least agree and that’s all I care about.
Agree in the sense, that yes if number of geometries is 0, then I expect ST_GeometryN of anything to give me NULL back. It has also been like that for quite some time so all supported versions I assume agree (I didn’t check 3.0).
Not worth breaking to me for a geometry I hope people aren’t even using and if they are using these, they are probably relying on this bug as a feature.
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Martin Davis
Sent: Friday, February 10, 2023 3:17 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Empty for Discussion
Note my result for ST_GeometryN is on PostGIS 3.1.4. More recent versions might be different (i.e. returning NULL)?
On Fri, Feb 10, 2023 at 12:02 PM Martin Davis <mtnclimb at gmail.com <mailto:mtnclimb at gmail.com> > wrote:
So seems to me that
ST_NumGeometries('GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)'::geometry)
==> 0
is inconsistent with
ST_GeometryN('GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)'::geometry, 1)
==> POINT EMPTY
I think ST_NumGeometries('GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)'::geometry) should return 2.
On Fri, Feb 10, 2023 at 11:39 AM Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca> > wrote:
select st_astext('GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)'::geometry);
select st_isempty('GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)'::geometry);
select st_numgeometries('GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)'::geometry); st_numgeometries
select st_astext(st_geometryn('GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)'::geometry, 1));
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230210/bfc5aeda/attachment.htm>
