[postgis-devel] Empty for Discussion
Regina Obe
lr at pcorp.us
Fri Feb 10 18:23:11 PST 2023
Oh something did change, I missed that Martin, was getting POINT EMPTY on
ST_GeometryN(..,1)
In PostGIS 3.1
Yes I see now on my PostGIS 3.1 - SELECT ST_AsText(ST_GeometryN('GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)'::geometry, 1));
I do get a POINT EMPTY,
But in my latest dev compile, get NULL back. It's possible this behavior change was to handle empty geom crashers.
I should add, I had changed here -- https://trac.osgeo.org/postgis/ticket/5240
All the dumps to just ignore empty geometries. It was easier than trying to get them to output a geometry for empties.
So I'd rather standardize on 0 for an answer and that ST_GeometryN should just return NULL.
I think the only concern there, is what should one expect with:
SELECT ST_AsText(ST_GeometryN('GEOMETRYCOLLECTION(POINT EMPTY, POINT(1 2))'::geometry, 1));
SELECT ST_AsText(ST_GeometryN('GEOMETRYCOLLECTION(POINT EMPTY, POINT(1 2))'::geometry, 2));
SELECT ST_NumGeometries('GEOMETRYCOLLECTION(POINT EMPTY, POINT(1 2))'::geometry);
In both my 3.1 install and dev branch, I get back an answer of:
Position 1: POINT EMPTY
Position 2: POINT(1 2)
NumGeometries: 2
> -----Original Message-----
> From: Regina Obe [mailto:lr at pcorp.us]
> Sent: Friday, February 10, 2023 7:39 PM
> To: 'PostGIS Development Discussion' <postgis-devel at lists.osgeo.org>
> Subject: RE: [postgis-devel] Empty for Discussion
> > > Agree in the sense, that yes if number of geometries is 0, then I
> > > expect
> > ST_GeometryN of anything to give me NULL back. It has also been like
> > that for quite some time so all supported versions I assume agree (I didn’t
> check 3.0).
> > Right, but we're talking about GEOMETRYCOLLECTION(POINT EMPTY, POINT
> > EMPTY) here, which has... 2 geometries in the collection.
> Yes the answer 2 is more right than 0 I suppose, but I don't think 0 is
> necessarily wrong either.
> If I collect all the candy bags from some kids and combine them and dump out
> all of the candy? How much candy do I dump out if no one went trick-o-
> treating = 0.
> As an accountant once send to me, as long as the answers all agree, that's the
> most important thing.
> ST_Dump, ST_DumpPoints, ST_GeometryN, ST_NumGeometries all agree, if
> you ask for nothing, you don't get something back.
> Should we change it, I say not worth the trouble unless there is a major issue
> you are seeing that is resulting.
> I'm more concerned about people relying on:
> ST_NumGeometries(GEOMETRYCOLLECTION EMPTY ) =
> ST_NumGeometries(GEOMETRYCOLLECTION(POINT EMPTY, POINT EMPTY)
> Having the same number of elements
> And that
> ST_DumpPoints and ST_Dump of empty geometries result in nothing being
> dumped.
> Fixing this will break their workflow.
> Thanks,
> Regina
