[postgis-devel] Promote Geometry to MultiGeometry on Insert
Raúl Marín
raul at rmr.ninja
Thu Feb 16 09:40:47 PST 2023
Makes sense to me.
I think that if there is a "sane" cast between types I think it's better
to accept it and it goes in the same approach as general PG types:
#create table a (a Integer);
#insert into a VALUES (0.4);
INSERT 0 1
#Select * from a;
a
0
Although I'd really keep it to just sane casts, like geom -> multigeom,
or multigeom(only_one_geom) ->geom.
Regards,
Raúl.
On 16/2/23 18:19, Paul Ramsey wrote:
> In 3.1 we started allowing people to insert SRID=0 geometries into columns with an SRID typmod, so that people wouldn't have to always add the SRID value when what they *meant* was to insert a conforming geometry into the column. SRID conflicts would still raise an error, but a SRID=0 is not a conflicting SRID, it's an unset SRID, so accepting the geometry and adding the typmod column made sense.
> In a similar vein, it kind of makes sense to accept simple geometries as input to multigeometry columns:
> CREATE TABLE mp (geom Geometry(MultiPolygon, 3005);
> INSERT INTO mp VALUES ('POLYGON(...)');
> SELECT ST_AsEWKT(geom) FROM mp;
> SRID=3005;MULTIPOLYGON(...)
> Again, in the spirit of "do what I mean". If 100% of the time, the response to a "geometry type mismatch" is just to wrap the input in ST_Multi(), the "data integrity check" isn't really helping, it's just adding a step to every interaction.
> Comments and concerns?
> P
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
