[postgis-devel] [postgis-users] Problem compiling postgis
Even Rouault even.rouault at spatialys.com
Fri Jun 2 10:07:10 PDT 2023
cf MapServer fix for similar issue:
https://github.com/MapServer/MapServer/pull/6833 (the issue was fixed in
upstream flatbuffers)
Le 02/06/2023 à 19:00, Paul Ramsey a écrit :
> Wait, we now have an implicit abseil dependency from flatgeobuf?
>> On Jun 2, 2023, at 9:48 AM, Pankaj K Garg <garg at zeemaps.com> wrote:
>> I cannot compile Postgis 3.3.3 (or 3.2.3) on Mac OS Ventura 13.4.
>> I installed *abseil* using brew. Abseil mandates the use of at least
>> C++14. PostGIS is trying the build flatgeobuf with C++11.
>> Will appreciate any help or pointers.
>> Thanks.
>> Pankaj
>> ---- Making all in postgis
>> /Applications/Xcode.app/Contents/Developer/usr/bin/make -C
>> ../deps/flatgeobuf all
>> gcc -std=c++11 -x c++ -I../../liblwgeom -I../../liblwgeom
>> -I./include-I/usr/local/Cellar/geos/3.11.2/include
>> -I/usr/local/Cellar/proj/9.2.0_1/include
>> -I/usr/local/Cellar/libtiff/4.5.0/include
>> -I/usr/local/Cellar/zstd/1.5.5/include
>> -I/usr/local/Cellar/jpeg-turbo/2.1.5.1/include-I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include-I/usr/local/Cellar/json-c/0.16/include
>> -I/usr/local/Cellar/json-c/0.16/include/json-c
>> -I/usr/local/Cellar/pcre2/10.42/include -DNDEBUG-fno-common -DPIC -c
>> -o flatgeobuf_c.o flatgeobuf_c.cpp
>> In file included from flatgeobuf_c.cpp:26:
>> In file included from ./feature_generated.h:7:
>> In file included from ./include/flatbuffers/flatbuffers.h:22:
>> In file included from ./include/flatbuffers/array.h:20:
>> In file included from ./include/flatbuffers/base.h:237:
>> In file included from /usr/local/include/absl/strings/string_view.h:39:
>> In file included from /usr/local/include/absl/base/attributes.h:37:
>> In file included from /usr/local/include/absl/base/config.h:86:
>> */usr/local/include/absl/base/policy_checks.h:79:2: **error: **"C++
>> versions less than C++14 are not supported."*
>> #error "C++ versions less than C++14 are not supported."
>> 1 error generated.
>> make[2]: *** [flatgeobuf_c.o] Error 1
>> make[1]: *** [../deps/flatgeobuf/libflatgeobuf.la] Error 2
>> make: *** [all] Error 1
>> 9:42 postgis-3.3.3 %
>> ZeeMaps http://www.zeemaps.com
>> 21060 Homestead Road, Suite 150 support at zeemaps.com
>> Cupertino, CA 95014                                            408
>> 914-2955
>> Like us on Facebook: http://www.facebook.com/zeemaps        Follow us
>> on Twitter: http://twitter.com/zeemaps
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230602/12995f94/attachment-0001.htm>
