[postgis-devel] [postgis-users] Problem compiling postgis
Regina Obe
lr at pcorp.us
Fri Jun 2 12:03:30 PDT 2023
I think he pushed the latest flatgeobuf in 3.4.0
Is it this one - https://github.com/postgis/postgis/pull/726
https://trac.osgeo.org/postgis/ticket/5368
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf
> Of Paul Ramsey
> Sent: Friday, June 2, 2023 2:54 PM
> To: Even Rouault <even.rouault at spatialys.com>; Björn Harrtell
> <bjorn.harrtell at gmail.com>
> Cc: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Subject: Re: [postgis-devel] [postgis-users] Problem compiling postgis
> Am I reading this right, we have flatgeobuf vendored in? Bjorn could you
> update our copy to what you think it a good state?
> On Fri, Jun 2, 2023 at 10:07 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
> > cf MapServer fix for similar issue:
> > https://github.com/MapServer/MapServer/pull/6833 (the issue was fixed
> > in upstream flatbuffers)
> > Le 02/06/2023 à 19:00, Paul Ramsey a écrit :
> > Wait, we now have an implicit abseil dependency from flatgeobuf?
> > On Jun 2, 2023, at 9:48 AM, Pankaj K Garg <garg at zeemaps.com> wrote:
> > I cannot compile Postgis 3.3.3 (or 3.2.3) on Mac OS Ventura 13.4.
> > I installed abseil using brew. Abseil mandates the use of at least C++14.
> PostGIS is trying the build flatgeobuf with C++11.
> > Will appreciate any help or pointers.
> > Thanks.
> > Pankaj
> > ---- Making all in postgis
> > /Applications/Xcode.app/Contents/Developer/usr/bin/make -C
> ../deps/flatgeobuf all
> > gcc -std=c++11 -x c++ -I../../liblwgeom -I../../liblwgeom -I./include -
> I/usr/local/Cellar/geos/3.11.2/include -I/usr/local/Cellar/proj/9.2.0_1/include
> -I/usr/local/Cellar/libtiff/4.5.0/include -I/usr/local/Cellar/zstd/1.5.5/include -
> I/usr/local/Cellar/jpeg-turbo/2.1.5.1/include -
> I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/
> Developer/SDKs/MacOSX.sdk/usr/include -I/usr/local/Cellar/json-
> c/0.16/include -I/usr/local/Cellar/json-c/0.16/include/json-c -
> I/usr/local/Cellar/pcre2/10.42/include -DNDEBUG -fno-common -DPIC -c -o
> flatgeobuf_c.o flatgeobuf_c.cpp
> > In file included from flatgeobuf_c.cpp:26:
> > In file included from ./feature_generated.h:7:
> > In file included from ./include/flatbuffers/flatbuffers.h:22:
> > In file included from ./include/flatbuffers/array.h:20:
> > In file included from ./include/flatbuffers/base.h:237:
> > In file included from /usr/local/include/absl/strings/string_view.h:39:
> > In file included from /usr/local/include/absl/base/attributes.h:37:
> > In file included from /usr/local/include/absl/base/config.h:86:
> > /usr/local/include/absl/base/policy_checks.h:79:2: error: "C++ versions less
> than C++14 are not supported."
> > #error "C++ versions less than C++14 are not supported."
> > 1 error generated.
> > make[2]: *** [flatgeobuf_c.o] Error 1
> > make[1]: *** [../deps/flatgeobuf/libflatgeobuf.la] Error 2
> > make: *** [all] Error 1
> > 9:42 postgis-3.3.3 %
> > ________________________________
> > ZeeMaps
> http://www.zeemaps.com
> > 21060 Homestead Road, Suite 150
> support at zeemaps.com
> > Cupertino, CA 95014
> 408 914-2955
> > Like us on Facebook: http://www.facebook.com/zeemaps Follow us
> on Twitter: http://twitter.com/zeemaps
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
> > postgis-devel mailing list
> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
> > http://www.spatialys.com
> > My software is free, but my time generally not.
