[postgis-devel] 3.4 Meet To Do - NOTE to packagers
Paul Ramsey pramsey at cleverelephant.ca
Mon Jun 19 12:40:24 PDT 2023
> On Jun 19, 2023, at 12:26 PM, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
> On 6/19/23 20:48, Regina Obe wrote:
>> Speaking of Proj items below.
>> Note to packagers:
>> Do you build proj > 7 ?
> Yes:
> https://tracker.debian.org/pkg/proj
>> If you build proj
>> 1) Do you have it built with curl support
> Yes:
> https://salsa.debian.org/debian-gis-team/proj/-/blob/debian/9.2.1-1/debian/control#L9
>> 2) If you have built with curl support
>>    Do you have the default set to PROJ_NETWORK=ON?
> No, default proj.ini is used:
> https://salsa.debian.org/debian-gis-team/proj/-/blob/debian/9.2.1-1/data/proj.ini
Does Debian get used with SELinux at all? How would flipping PROJ_NETWORK to “on” work in that case?
Is doing the network pull considered
- “something the library is allowed to do if turned on” or
- “no you cannot do that, that would be dumb”.
P
>> 3) If you do neither of the above, how much of the https://cdn.proj.org/
>> Do you ship?
> None, because proj-data has outstanding license issues:
> https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=952459#10
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
