[postgis-devel] Proj GUCs
Regina Obe lr at pcorp.us
Tue Jun 20 14:28:36 PDT 2023
I like it.  Though others might find it too cluttered.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf
Of Paul Ramsey
Sent: Tuesday, June 20, 2023 5:08 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Proj GUCs
On Jun 20, 2023, at 1:27 PM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> >
wrote:
I like the informational functions a lot :)
A function that tells you where your proj data is will be a good one too
As must of my time is spent hunting figuring out where the proj data is that
postgresql is using is.
Just stuffing the extra info into the proj version string looks like this:
postgis_reg=# select postgis_proj_version();
 9.2.1 PROJ_NETWORK=OFF PROJ_URL_ENDPOINT=https://cdn.proj.org
PROJ_GRID_DIRECTORY=/Users/pramsey/Library/Application Support/proj
(1 row)
postgis_reg=# select postgis_full_version();
 POSTGIS="3.4.0dev 3.3.0rc2-988-g9ec3f4bc5" PGSQL="150"
GEOS="3.12.0dev-CAPI-1.18.0" PROJ="9.2.1 PROJ_NETWORK=OFF
PROJ_GRID_DIRECTORY=/Users/pramsey/Library/Application Support/proj"
LIBXML="2.9.13" LIBJSON="0.16" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230620/7b56c7ea/attachment-0001.htm>
