[postgis-devel] Proj GUCs
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jun 22 12:07:48 PDT 2023
> On Jun 22, 2023, at 11:44 AM, Regina Obe <lr at pcorp.us> wrote:
> Strk, pramsey -- are you offended by the misnomer here?
> Now that Greg mentioned it, it does bother me a little, but I do like the
> single function that tells me
> everything I care to know about someone's PostGIS setup.
Not offended at all. I think it’s fine, and I rather dislike the idea of proliferating another function. Anyone who is parsing this string can still parse it fine, all the proj info is between the “” in the proj section.
P
> But if we go the path of having *_config functions
> might as well make it json to separate it out a bit.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230622/825384c8/attachment.htm>
