pkg-config
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 20 15:43:40 PST 2023
> On Nov 20, 2023, at 3:41 PM, Regina Obe <lr at pcorp.us> wrote:
>> I am re-working the GEOS detection in the configure script a bit, and I have the
>> following logic:
>> if (geos-config provided)
>> use geos-config
>> else
>> if (pkg-config found)
>> use pkg-config
>> elseif (geos-config on path)
>> use geos-config
>> else
>> error cannot find geos
>> Is that the right order? I noticed that libxml2, just prior to geos in the configure
>> script, prefers xml2-config to pkg-config if it exists.
>> P
> You know I don't think I've ever attempted to pass geos-config on path. Not that it doesn't work, just didn't realized that was even supported, or are you adding that?
That’s always been there. If you don’t specific geos-config, it will pick up the first one it finds on the path. And in fact in the current state will prefer that over pkg-config.
> The only possibly incomplete thing I see in you code is:
> What if you have pkg-config, but you can't find geos with it? Does it eventually end with can't find geos, or tries to look for it in on path?
Then the next fall-back is looking for geos-config in the path. And if that fails it errors out.
> In my case, I put all the pkg_config stuff in PKG_CONFIG_PATH as shown here
> https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/ci/winnie/winnie_common.sh#L119
> cause well I'm constantly switching versions of libraries. But it is possible I make a typo.
> Thanks,
> Regina
