[postgis-devel] PSC Vote: Circle CI signup for Free plan -MOTION PASSED
Imre Samu
pella.samu at gmail.com
Thu Sep 7 19:39:44 PDT 2023
Regina Obe <lr at pcorp.us> ezt írta (időpont: 2023. szept. 7., Cs, 17:48):
> No one had any reasons not to and I gave a +1.
I did a setup for docker-postgis in a separate branch.
> https://github.com/postgis/docker-postgis/tree/circleci-project-setup
Thank you!
> I’m assuming all that needs to be done is create a circle-ci in the main
> repo? To complete the job
> I assume Imre can use his working one for that.
Imre,
> Let me know if I need to do anything else.
Currently, I can work with this and face no issues.
However, after I've tested everything, there will be a need to set up:
- DOCKERHUB_USERNAME
- DOCKERHUB_ACCESS_TOKEN
in the CircleCI environment.
I'll let you know when.
Regards,
Imre
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20230908/017c29c5/attachment.htm>
