relate_bnr.sql
    Imre Samu
    pella.samu at gmail.com
    Tue Aug 20 18:01:18 PDT 2024
Paul Ramsey <pramsey at cleverelephant.ca> ( 2024. aug. 20., K, 21:39):
> If we leave the stable branches alone, that will mean that anyone
> upgrading GEOS underneath postgis 3.4 and lower will end up with regression
> failures.
I also encountered this issue with the docker-postgis *-master images,
where the latest developer commit from GEOS ("main" branch) is being used.
Currently, I'm using the GEOS "3.12" branch for this reason as a workaround.
( https://github.com/libgeos/geos/tree/3.12 ).
So, I would also appreciate some sort of solution,
although the problem is no longer critical with the workaround in place.
Currently, debian 'experimental' has already started using the geos
3.13.0~beta1-1~exp1 .
https://packages.debian.org/experimental/source/geos
Imre
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240821/729edf60/attachment.htm>
