GEOS 3.13 and GEOSMessageHandler
    Paul Ramsey
    pramsey at cleverelephant.ca
    Wed Aug 21 15:02:16 PDT 2024
OK, so the lwgeom_geos.h header currently has this abomination in it
#if POSTGIS_GEOS_VERSION < 31300
#if __STDC_VERSION__ >= 201112L
/* See https://github.com/libgeos/geos/pull/1097 */
/* Only redefine the typedef if compiler is C11 or higher */
typedef void (*GEOSMessageHandler)(const char *fmt, ...) __attribute__ (( format(printf, 1, 0) ));
#endif
#endif
The bit in the middle is us overriding the GEOS typedef for message handler, not for any purpose but to quiet a warning. I’m not sure when we started getting it, or when GEOS started getting it, but it resulted in GEOS’s definition of the message handler including some __attribute__ information. That cleans up warnings for anything using GEOS >= 3.13.
But for older GEOS, there’s still a warning where we *use* the message handler, not just where we define it. So we’re getting warnings in the PostGIS build too. Again, I don’t know why we have this warning now. But I’d say, having read up on what we get from adding the __attribute__ information (a theoretical improvement in avoiding making mistakes using format strings?) quieting the warnings in our code seems like the wrong answer. I’d say we should just ignore the warnings by stripping the check, at least for versions of GEOS (<3.13) that we know have the old, non-attributed message handler typedef.
So I propose adding this to the PostGIS configure.ac
dnl Turn off attribute warnings for GEOS < 3.13
if test "$POSTGIS_GEOS_VERSION" -lt "31300"; then
	_LT_COMPILER_OPTION([if $compiler supports -Wno-suggest-attribute=format], [_cv_nosuggestattribute], [-Wno-suggest-attribute=format], [], [CFLAGS="$CFLAGS -Wno-suggest-attribute=format"], [])
fi
Just tell the compiler to shut up about this warning, except for places where we have some control over it, namely with GEOS >= 3.13
P
