Should we call it quits on support for 32-bit
Regina Obe lr at pcorp.us
Thu Aug 22 10:10:17 PDT 2024
At the very least, I'm going to turn off 32bit testing on gitlab, cause that's the most annoying right now and nothing we've been able to replicate on the other 32-bit cis we have and having that 32bit running, makes it difficult to see when there are 64-bit reds on gitlab.
I still think the berrie crasher we should fix.  I'll try to look at that later this week or next so I start getting greens on that.
> -----Original Message-----
> From: Paul Ramsey <pramsey at cleverelephant.ca>
> Sent: Thursday, August 22, 2024 12:10 PM
> To: Regina Obe <lr at pcorp.us>
> Cc: Greg Troxel <gdt at lexort.com>; PostGIS Development Discussion <postgis-
> devel at lists.osgeo.org>
> Subject: Re: Should we call it quits on support for 32-bit
> There’s a theory and practice thing going on here. All the effort going into
> maintaining 32-bit CI is kind of wasted if none of the issues ever gets fixed.
> And the lack of easy access to workable 32-dev dev envs makes it unlikely they
> will get any attention. Also, the last of 32-bit users strongly depresses the
> sense of any particular urgency to addressing the issues. They *might* be
> symptoms of some other larger problem. Or they might be quirks of the 32-bit
> platform. So, priority ends up low.
> ATB,
> P
> > On Aug 19, 2024, at 4:41 PM, Regina Obe <lr at pcorp.us> wrote:
> >> I just kicked off a build of postgresql 16 on a NetBSD 10 RPI3 with
> >> 1G of
> > RAM,
> >> running as earmv7hf-el.  I'll see how that goes and then build
> >> postgis
> > (sticking
> >> to releases first).
> > Thanks Greg let us know how this goes.
> > Yah part of me feels that these are real issues because of invalid
> > types and so we gain something from still testing on these
> > architectures and trying to fix them in due time.
> > But the other part of me just wants those 32-bits off our CI trac
> > radar.  So my first thought is just remove them, maybe check in to
> > make sure they still compile or reduce the tests down to just "It
> > compiles" we are done.
> > https://trac.osgeo.org/postgis  (the FreeBSD 12 x86 32-bit, which I
> > know I got to upgrade still seems to be doing okay).
> > So that way, we can say, we do not guarantee all tests will pass on
> > 32-bit architectures.
> > To be fair to berrie, berrie (our Rasberry pi arm 32-bit running
> > Debian 11 ) does just fine on the regular tests.
> > It's our garden crasher of tests designed to crash servers with
> > invalid inputs that she's crashing on and I think at the moment only
> > our Rasberries are doing those crasher tests and Arm 64 is doing just
> > fine on that suite of tests.
> > The gitlab one is more troubling just returning wrong answers and
> > nothing I can replicate on any of the other 32-bit cis we have.
