GEOS 3.13 and GEOSMessageHandler
    Sandro Santilli
    strk at kbt.io
    Thu Aug 22 10:14:52 PDT 2024
On Thu, Aug 22, 2024 at 08:23:20AM -0700, Paul Ramsey wrote:
> /usr/local/include/geos_c.h:105:16: warning: redefinition of typedef 'GEOSMessageHandler' is a C11 feature [-Wtypedef-redefinition]
> typedef void (*GEOSMessageHandler)(const char *fmt, ...);
> ../../liblwgeom/lwgeom_geos.h:28:16: note: previous definition is here
> typedef void (*GEOSMessageHandler)(const char *fmt, ...) __attribute__ (( format(printf, 1, 0) ));
> A fairly reasonable warning, IMO, since redefining something we are pulling in from another library is quite a bit of a hack, and dangerous in its own right.
It'd dangerous only if the upstream definition can change, but we're
only redefining for GEOS versions below a given number os we know the
definition is NOT going to change, removing that danger.
All you need is to tell your compiler that you are using C11 features ?
--strk;
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240822/3f9db346/attachment-0001.sig>
