GEOS 3.13 and GEOSMessageHandler
Sandro Santilli
strk at kbt.io
Wed Aug 28 06:06:50 PDT 2024
On Wed, Aug 28, 2024 at 06:53:47AM -0400, Greg Troxel wrote:
> Sandro Santilli <strk at kbt.io> writes:
> > We're passing -std=gnu99 as a compiler switch when available [1],
> > but if I pass -pedantic to the build line I get notified that
> > PostgreSQL headers use C11 constructs:
> > /usr/include/postgresql/16/server/storage/lwlock.h:63:1: warning: '_Static_assert' is a C11 extension [-Wc11-extensions]
> > I don't find any indication in the README as to which capabilities the
> > C compiler must have. What about going -std=gnu11 and see how it goes ?
> > Note we use C++11 for Wagyu and FlatGeobuf.
> > [1] https://trac.osgeo.org/postgis/ticket/4234
> I would suggest --std=c11, not gnu11. I realize many gnu extensions are
> popular, and that clang mostly has them, but in portable code I view use
> of them as bugs.
We'd need to adapt some code for -std=c11, like:
liblwgeom/measures.c:2482:35: error: ‘M_PI_2’ undeclared (first use in this function)
(works fine with -std=gnu11)
> With use of c++11, I don't see any reason to avoid c11. Are there
> non-ancient non-broken environments where the compiler supports c++11
> but not c11?
I've pushed this "c11" branch that's currently using -std=gnu11 and CI
bots seem happy with it.
What I'd like to know is if it fixes Paul's warning with the typedef
redefinition as that's what we're aiming at.
--strk;
Libre GIS consultant/developer
https://strk.kbt.io/services.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240828/03e7c873/attachment.sig>
