Curve Thoughts
Regina Obe lr at pcorp.us
Fri Feb 16 14:29:50 PST 2024
> > On Feb 16, 2024, at 1:38 PM, Regina Obe <lr at pcorp.us> wrote:
> > ST_GeometryN(<>, 4)
> > Should return the 4th record that ST_Dump returns.
> Worth noting: this is not possible. ST_Dump recurses into collections,
whereas
> geometryN only lets you pick from elements of the top-most collection.
> P
Okay I'll be content with  ST_NumGeometries and ST_GeometryN agreeing
I'm okay with treating Compoundcurve and CurvePolygon as collections as you
propose here
  https://gist.github.com/pramsey/cbf6db1edb8762854925f6b6ad6d6b35
Since the unitary paths sounds painful both in changes and backward
compatibility to perhaps not be worth the effort.
I'm a little confused by this though
https://gist.github.com/pramsey/cbf6db1edb8762854925f6b6ad6d6b35#proposal-fo
r-curvepolygon
if you are treating a curved polygon like below as a collection?
CURVEPOLYGON(COMPOUNDCURVE(
    LINESTRING(2 2, 2.5 2.5),
    CIRCULARSTRING(2.5 2.5, 4.5 2.5, 3.5 3.5),
    LINESTRING(3.5 3.5, 2.5 4.5, 3 5, 2 2)),
    LINESTRING(4 4, 4 5, 5 4, 4 4)
As a collection, how do you end up with this:
ST_GeometryType(ST_Dump(geom).geom) => ST_CurvePolygon
Shouldn't the answer be the same as it currently is with:
SELECT dp.path, ST_GeometryType(geom)
FROM ST_Dump('CURVEPOLYGON(COMPOUNDCURVE(
    )'::geometry) AS dp;
path  |  st_geometrytype
 {1,1} | ST_LineString
 {1,2} | ST_CircularString
 {1,3} | ST_LineString
 {2}   | ST_LineString
(4 rows)
e.g. just like in a geometrycollection, a multipolygon or a polyhedral
surface, the outer type no longer exists
