st_union(geom[]) does not union single-geometrycollection arrays
Dian Fay
di at nmfay.com
Sat Feb 24 15:16:22 PST 2024
Postgres 16.1
postgis_version: 3.4 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
I've produced some geometrycollection arrays from
st_clusterintersecting. Now I want to combine each cluster, to end up
with as many simple geometries as there were originally clusters. This
turns out to work well as long as I have multiple clusters. When the
array contains only one geometrycollection -- in other words, _all_ the
original geometries overlapped and should be combined -- it doesn't.
Here's a distilled example showing a successful cluster simplification
with two clusters:
select
st_asewkt(
st_union(
array[
st_geomfromtext(
'GEOMETRYCOLLECTION(
POLYGON((0 0,10 0,25 25,0 10,0 0)),
POLYGON((20 20,30 20,30 30,20 30,20 20))
st_geomfromtext(
POLYGON((100 100, 110 100, 110 110, 100 100))
The polygons in the first collection overlap and are merged:
MULTIPOLYGON((
(10 0,0 0,0 10,20 22,20 30,30 30,30 20,22 20,10 0)),
((110 100,100 100,110 110,110 100))
However, remove the second geometrycollection:
select
st_asewkt(
st_union(
array[
st_geomfromtext(
And st_union doesn't touch it:
GEOMETRYCOLLECTION(
Since this does pull it out of the array, I can get the result I'm after
by nesting `st_union(st_union(array[....]))`. But it's counterintuitive,
at least to me, that `pgis_union_geometry_array` skips these. Should the
"one geom, good geom" case really apply to geometrycollections or is it
meant more for simple geometries?
