ST_DFullyWithin
Martin Davis mtnclimb at gmail.com
Thu Jan 25 11:57:22 PST 2024
Another reason for keeping the meaning "ST_DFullyWithin(A, B) =
ST_Covers(ST_Buffer(A, Dist), B)":
I see the main use of this function in queries to be "find all the B
features which are fully within distance D of an A feature".  So the A
feature is the *constant* "query item", and it is evaluated against a set
of B features.  It seems more intuitive for the constant feature to be the
first argument in functions.
PS note the definition needs to use Covers rather than Contains, due to
that ol' quirky definition of Contains!
On Thu, Jan 25, 2024 at 10:57 AM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> On Jan 25, 2024, at 10:19 AM, Bruce Rindahl <bruce.rindahl at gmail.com>
> wrote:
> I agree with Regina.  Also why are we coding this as a function in C when
> it can be done either of two ways in SQL:
> In general functions in SQL are less fun to upgrade. Will eventually do
> this via Hausdorf.
> I don’t know that I agree about the parameter ordering, and I do not think
> the name of the function provides any guidance when I re-write it in object
> form,
> A.DFullyWithin(B,R)
> at least not in the same way that
> A.contains(B)
> makes parameter meaning clear.
> It’s the “D” that wrecks it.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20240125/c80b9e42/attachment.htm>
