PostGIS 3.5.0alpha2 released supports PG17
Regina Obe lr at pcorp.us
Sat Jul 6 12:15:55 PDT 2024
PostGIS 3.5.0alpha2 is released.  This version fixes an issue with the tar
ball that made it fail because of test failures
discovered by Bas Couwenberg
https://trac.osgeo.org/postgis/ticket/5759
This version requires PostgreSQL 12 - 17, GEOS 3.8 or higher, and Proj 6.1+.
To take advantage of all features, GEOS 3.12+ is needed.
To enable postgis_sfcgal support SFCGAL 1.4-1.5 is required.
To take advantage of all SFCGAL features, SFCGAL 1.5 is needed.
Details here:
https://postgis.net/2024/07/PostGIS-3.5.0alpha2/
NEWS: https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.5.0alpha2/NEWS
Source: https://download.osgeo.org/postgis/source/postgis-3.5.0alpha2.tar.gz
Please report on our ticket tracker if you run into issues
Thanks,
PostGIS Development Team
